46 Users Online (44 Members):
Forums >> General Discussion >> Revit Project Management >> import
2 Posts No Rating |
I do not know how to eliminate what apprears to be construction lines from a Revit City import rock 1 8607.rfa.
I would also like to control colors, materials and size of the imported rock.
A link to an appropriate video would be great.
Thanks,
Andy
Boulder1 was not created to be parametric so you have to change the actual family to make it bigger or smaller. You can control the material by applying a material parameter to it in the family.
Rock08607 is a .sat file so there is nothing you can do to it except change the color, this can be done in the family under materials. You will need to change the Rock 01 materials to what you want them to be.
Deleting import symbols |
Thu, May 8, 2008 at 3:14:21 PM
Import DWG problem with size |
Mon, Dec 6, 2010 at 7:33:32 PM
Import SAT file |
Fri, Nov 30, 2012 at 9:42:19 AM
Best way to import |
Mon, Oct 28, 2013 at 1:43:00 PM
Importing some CAD layers then wanted to import some more... |
Tue, Jan 2, 2007 at 12:19:53 AM
Members: | 2026154 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
