Forums >> Revit Building >> Technical Support >> Issues with Drafting Hatch
7 Posts No Rating |
Hello,
I am using Revit 2014. I am trying to change the scale of a hatch pattern in my section views. I'm not sure if it's a progrm bug, but sometimes when I change the line spacing, it will affect how it looks in the section view. Other times when I change the line spacing, it doesn't change anything. Is there a limit to the line spacing? I am using a repeating detail with the brick section and changing the hatch pattern in the family. Even when I change the view scale of the family to the same as the wall section, they still look different and the section will not match the family.
Thank you.
From your HELP:
Drafting Patterns
Drafting patterns represent materials in symbolic form; for example, sand is represented by a stipple pattern. The density of drafting patterns is fixed with respect to the drawing sheet.
7 Posts No Rating |
Thank you for the reply. But I don't understand why the density of the lines don't change when I change their spacing in the family editor.
The project rules..... If the pattern is in the project then that description is used. To define something different, you have to use a unique name.
7 Posts No Rating |
I did that already. I duplicated the diagonal hatch and renamed it brick.
7 Posts No Rating |
Here are screen shots of my family and how it looks in the sections....at the same scale.
7 Posts No Rating |
Oops this is the one at the right scale
As I said.... THE PROJECT RULES.... once a pattern (or material) is defined or loaded into a project by way of a family, the the project dictates how it is displayed. You can change it all you want in the family and it will not change a thing in the project.
7 Posts No Rating |
So what do you recommend? You had said "To define something different, you have to use a unique name" - how do I do this?
"Brick" sounds like a hatch you would already have in a project so that might be a bad use here but if it isn't, then delete your family from the family browser in the project and all instance then delete the drafting pattern called brick in the project and re-load your family. Now you have redefined it in the project..... Or give it a new name in the family and then load it. But then know - the project will rule once again.
7 Posts No Rating |
I'll try that, thank you for your help!
Cant rotate drafting style pattern? |
Thu, Aug 18, 2011 at 11:08:52 AM
12
hatch editing Rev 2009 |
Fri, Jul 8, 2011 at 11:23:09 AM
2D Stone Hatch for Drafting Views |
Wed, Mar 20, 2013 at 9:47:40 AM
Importing a CAD site plan w/ hatch |
Tue, Aug 30, 2011 at 1:51:06 AM
Surface Hatch Pattern on Topography/Subregions |
Fri, Oct 24, 2008 at 11:30:56 AM
