57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> how to use cut plan for different level
Thu, Feb 23, 2006 at 6:46:56 AM | how to use cut plan for different level
why8888
does anyone know how to set the view range for different level at one sheet? e.g. i have two buildings 8m apart, and have 2m difference of level, i want to show them at one sheet, and show the doors on the plan. because they are at the different level, if i set up the view range for one building, the other building would only see the door head. what can i do? onho
Thu, Feb 23, 2006 at 8:45:05 PM | RE: how to use cut plan for different level
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
. You need to creat a 'Plan Region'. This allows multiple cut planes all within one view. Perfect for a split level situation or when a window is up to high on a wall etc.... Basically you can define an area in a view that has a different Cut Plane. Below is a link to a quick video that uses plan regions: http://www.dgcad.com/downloads/FURNITURE-PLAN-REGION.wmv Also, there are many more video tutorials on Views etc at: http://www.dgcad.com Lesson 6 or the REVIT series has lots of goodies on this topic. Enjoy, DG
Fri, Feb 24, 2006 at 12:03:35 AM | RE: how to use cut plan for different level
why8888
thank you so much. onho
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:24 AM
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:54 AM
create cellar level/floor plan below level 1 afterwards
Mon, Jun 26, 2006 at 8:24:52 PM
I made a Level without a floor plan... but now I want one.
Fri, Dec 5, 2014 at 4:47:53 PM
Floor Plan associated to wrong level...
Fri, Jul 2, 2021 at 3:23:05 PM
Page generation time: 0.8543
