49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Symbolic Lines in Beam Families
Mon, Feb 24, 2014 at 1:54:19 PM | Symbolic Lines in Beam Families
xXSuperDaveXx
I have a Beam family which is a square hollow section. I have drawn the hidden lines foe inside edges using symbolic lines, when I cut a view of each face of the hollow section in the family editor I see the hidden lines for the inside edges of the SHS but when I load the family into the project there is one face of the beam that does not show hidden lines (depending on the cross section rotation) Does anyone know why this might be happening? I am thnking it might be the "ceiling plan" in the family that needs the symbolic lines applied but the extrusion does not show up in this view.
I have attached the said Family, If someone could have a look I would greatly appreciate it.
Thanks.
Mon, Feb 24, 2014 at 3:54:58 PM | Symbolic Lines in Beam Families
xXSuperDaveXx
**EDIT** The glitches in this post are only happening in the one view, I will need to investigaqte further, the initial problem with the SHS beam is persistant. and Ideas would be helpful. Thanks.
The SHS coulmn 'plots' the hidden symbolic lines but does not show them on the screen in views...
The UC column shows its own hidden lines aswell as the symbolic hidden lines, I would like it to show ONLY the symbolic hidden lines.
Edited on: Mon, Feb 24, 2014 at 4:01:25 PM
Edited on: Mon, Feb 24, 2014 at 4:02:17 PM
symbolic lines
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic/Model lines bug!
Wed, Oct 21, 2009 at 1:39:23 AM
Altering Revit Structure Wood Beam Families
Mon, May 14, 2012 at 2:10:01 PM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Page generation time: 17.6666
