Forums >> Revit Structure >> Technical Support >> Cuts on reference planes dropping off when elements are moved
Thu, Feb 20, 2014 at 7:03:36 PM | Cuts on reference planes dropping off when elements are moved
xXSuperDaveXx
When I 'move' an element that has its end(s) cut on a refenence plane they loose thier ascociation with the plane and the cuts drop off however when I 'align' or 'drag' an element the cuts stay on the reference planes. I am the only one in this office this happens to and I cannot work out why it happens, it is very frustrating.
Does anyone know how to fix this? Thanks.
Fri, Feb 21, 2014 at 7:10:06 AM | Cuts on reference planes dropping off when elements are moved
Are you moving with disjoin checked?
Sun, Feb 23, 2014 at 1:41:30 PM | Cuts on reference planes dropping off when elements are moved
xXSuperDaveXx
no disjoin is not checked, have also tried turning constrain on and off with no luck
Mon, Feb 24, 2014 at 1:48:03 PM | Cuts on reference planes dropping off when elements are moved
xXSuperDaveXx
-Bump
Any Ideas?
Mon, Feb 24, 2014 at 1:53:38 PM | Cuts on reference planes dropping off when elements are moved
I can pretty much understand why move doesn't work because the association to the cutting plane is lost.  What I have trouble understanding even yet is what is the logic on dragging buttons.  On some objects, the object moves.  On others, the object changes length.  I believe this depends on which end was the creation start but I have not tested by theory.
Sorry, I can't give you more help.
Thu, Feb 27, 2014 at 6:07:22 PM | Cuts on reference planes dropping off when elements are moved
xXSuperDaveXx
Seems to work on everyone elses PC in the office, Kind of annoying having to recut an element every time you move it yet if you drag or align the element it keeps its cuts.
Hidden Reference Planes disappeared
Fri, Jun 30, 2017 at 11:50:56 AM
Listing the Abilities of Reference Planes
Sun, Sep 9, 2012 at 9:24:07 PM
reference planes
Wed, May 24, 2006 at 10:19:12 AM
Detail Lines and Reference Planes
Tue, Sep 20, 2016 at 2:37:46 PM
Reference Plane Dimension
Sat, Aug 20, 2005 at 7:33:46 PM
Page generation time: 0.6733
