35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Cannot rotate a family in elevation-Ii it possible?
Wed, Feb 19, 2014 at 9:58:46 AM | Cannot rotate a family in elevation-Ii it possible?
SalvadoFlores
Hi there,
Ok, I understand that Revit is different from AutoCAD and I’m willing to learn whatever process it is to rotate a family in elevation, now as I’m relatively new user of Revit I would like to know something very simple, it might sound stupid but I do not have a clue about it.
Here I go: I have opened a new family file (mass concept) and created a simple mass cube, unticked every box (always vertical off etc), the question is: What do I need to do for this simple cube to rotate once is loaded in a project file. That will help me to understand most of the process, I think.
Many Thanks for your help in advance.
S
Wed, Feb 19, 2014 at 10:11:10 AM | Cannot rotate a family in elevation-Ii it possible?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you read any of the similar threads below?  Why are you making a cube as a mass?
Fri, Feb 21, 2014 at 5:37:28 AM | Cannot rotate a family in elevation-Ii it possible?
SalvadoFlores
Thanks for the links, it did actually work, secret was (at least in my case) to create the family with a Metric Generic Model face based, that did the trick for me. Now everything rotates in elevation.
Cheers!
Can't Rotate Revit Family Created
Mon, Dec 3, 2012 at 2:21:24 PM
Made a new family but ant rotate it properly
Mon, Jun 13, 2011 at 12:32:45 PM
Rotating a family in elevation
Sat, Sep 15, 2018 at 12:16:57 PM
Is it possible to rotate footing / elevation / etc. tags?
Tue, Feb 2, 2010 at 1:28:40 PM
How to fix the elevation pointer no rotate with object ?
Fri, Sep 2, 2011 at 6:58:11 AM
Page generation time: 8.3700
