59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Scale issues
Tue, Feb 18, 2014 at 9:55:26 AM | Scale issues
danher1974
Hi,
I have attached an example of a plan i have at 1:100 and what happens when I change the scale to 1:500.
As you can see the grids and text go huge when the scale is changed to 1:500, does anyone know what settings i need to change to amned this?
thanks
Tue, Feb 18, 2014 at 9:58:29 AM | Scale issues
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is the size it needs to be in order to print actually 3/32", 1/8" etc.  If you want smaller text you will need to change your text from (for example) 1/8" to 1/16"
Tue, Feb 18, 2014 at 10:02:38 AM | Scale issues
danher1974
Hi,
But what about the grid bubbles and the room tags?
thanks
Tue, Feb 18, 2014 at 10:18:10 AM | Scale issues
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
These are ALL annotations and follow the same rules.  If they didn't change with the view scale you wouldn't be able to read them when they print.  If you NEED them smaller you will need to edit the family
Tue, Feb 18, 2014 at 10:26:50 AM | Scale issues
danher1974
Hi,
So what about if I want one drawing sheet with a plan at 1:500 and another drawing sheet with a plan at 1:200?
Will I have create two separate plans with different grid and text sizes?
thanks
Tue, Feb 18, 2014 at 10:34:46 AM | Scale issues
Most individuals recognize that reading the number is what is important.  On very small scales we usually turn off all but the first and last column numbers.... or maybe every other one or similar approach but the bubble size stays the same in all views.
PAT file scale issues
Thu, Mar 20, 2008 at 7:03:28 AM
Scale Issues in Titleblock
Thu, May 2, 2013 at 5:01:38 AM
3ds Max .fbx and UVW issues
Wed, Sep 3, 2008 at 11:02:09 AM
PRINTING ISSUES. When printing to CutePDF my drawings won't come out to scale.
Tue, Sep 6, 2011 at 7:51:06 AM
Scale bar on sheet onto to display at certain scale
Wed, May 22, 2013 at 12:15:22 AM
Page generation time: 8.0489
