60 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> Callout/ Section/ Elevation marks on parallel plans
3 Posts No Rating |
What governs whether an annotation (callout, section, elevation) appears or not on two parallel plan views?
Example: make a floor plan. Make another plan view, same floor, same scale, call it 'furniture plan'. Cut a section of a wall on one. Miraculouly, it works in this scenario, yet I have the same thing going on an existing project and it's not happening. What does it take to get it to show up on the other? Why does it do so sometimes and not other times? What is the rule? How do you get the callout to show up on the other view? If you select the annotation, copy it to clipboard, go to other view Paste>current view, it makes a DUPLICATE view! The non-showing annotation is not 'hidden', mousing over doesn't bring it around.
Any insights? Thanks
4 Posts No Rating |
did you already check the option in properties of the Section/Callout.
For Section, the Graphics Properties "Hide at scales coarser than"
For Callouts, under Graphics Properties "Show in Parent view only"
One more thing that comes to mind is, In the view that you want it to show and its not showing, check the Visibility Properties as well.
Hope this helps!
SL
3 Posts No Rating |
Ah-ha! Thank you. Different fix for different annotations...
That did it. The duplicated view had its scale changed to 3/32" to fit a sheet...
Thank you Suganya
Section marks appearing on plans |
Thu, Dec 6, 2012 at 4:26:26 AM
Phases and Elevation or Callout Marks |
Sat, Sep 26, 2009 at 8:49:53 AM
section marks |
Tue, May 17, 2005 at 12:54:13 AM
Linked Views - seeing section and elevation marks R2015 |
Wed, Jul 29, 2015 at 4:53:32 PM
Elevation Lines and floor plans |
Wed, Jan 26, 2011 at 12:21:39 PM
Members: | 2016890 | Objects: | 22944 | Forum Posts: | 152211 | Job Listings: | 3 |
