43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Simple Question? : Load curse'y views into Project...
Fri, Feb 14, 2014 at 3:51:34 PM | Simple Question? : Load curse'y views into Project...
Godhand123
I have a pretty simple question..
I've build a bunch of custom panels/clamps and made a Revit Warehouse with these panels/clamps that I can reference when I need them in a project.
I can make an assembly from each of these custom panels, and create several parametric views in the warehouse.  I've done this with all of these panels.  I've dimensioned the views and if I change the size of the panel the dimensions update.. perfect.
Now if I load those panels into a project (copy/paste) the panel comes in as an assembly, but the parametric views do not come with it.
My main goal this: If I have a project that requires a custom panel I can go into the warehouse and grab the panel, copy/paste into the project and then use the detail drawing that is built into the curse'y.  If I change the panel once it's in the project the curse'y views will update.
Is this possible?  Any workarounds?
Thanks!
Tue, Feb 18, 2014 at 12:41:02 PM | Simple Question? : Load curse'y views into Project...
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
What do you mean by curse'y ?
Planta1 Revit Online Consulting | info@planta1.com
cannot load families into my project
Tue, Aug 15, 2006 at 2:20:22 PM
'Door' Won't Load into Project
Tue, Sep 28, 2010 at 7:11:38 PM
I can't load anything from my library.
Thu, Jul 25, 2013 at 10:16:11 AM
Family Won't Load
Tue, Nov 28, 2017 at 8:50:39 AM
Simple Roof Question
Mon, Aug 8, 2011 at 6:47:09 PM
Page generation time: 3.0753
