41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Topo surface Control from imported contours
Wed, Feb 12, 2014 at 10:39:22 PM | Topo surface Control from imported contours
Reddrev
When I import a contour drawing and create surface etc,   the edge of the contours join together and create "inclined walls" of surface.  How can I edit the source CAD file or revit to prevent this?
Image attched - red line shows what I calkl the inclined wall surface created by the joined edges of the contours.
Many thanks
Thu, Feb 13, 2014 at 3:28:13 AM | Topo surface Control from imported contours
4 Stars: 203 Votes
In Revit you can "Split" that surface and delete part of the surface you don't want/need OR you can EDIT that surface in Revit and add extra points if that's what you want.
Mon, Feb 17, 2014 at 12:03:49 AM | Topo surface Control from imported contours
Reddrev
Thanks for that, I will try Revit editing the surface, but I was also wondering what I can do in the CAD survey file to prevent it at source.
Mon, Feb 17, 2014 at 7:28:50 AM | Topo surface Control from imported contours
If your site doesn't really look like that then your imported CAD survey has some bad points.  Look at that in 3D and you should see the really bad ones.  But this is the resposibility of the surveyor.  Point it out to him.
Smoothing contours...
Tue, Feb 17, 2009 at 8:43:15 AM
topo contours are offsetting in z direction
Fri, Mar 27, 2015 at 5:42:46 PM
Cutting a topo surface
Thu, Oct 13, 2011 at 11:01:48 AM
Creating Topo using an image
Mon, Feb 21, 2011 at 2:18:33 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:11 PM
Page generation time: 11.0024
