Forums >> Revit Building >> Technical Support >> Ortho Drawing Precision / Project North Alignment
24 Posts No Rating |
Hi there,
I'm having a very frustrating time setting up a new project with its Project north.
The Othogonal alignment of the project is about 45.113d from the geographic north. When I rotate a plan view (project north) to align to an orthogonal element (site boundary etc) on the site survey DWG file, the view turns as it should - all is well - the reference element appears perfectly horizontal on my view.
THEN, I draw something: a line, section, grid etc, I wait for the ortho mode to say HORIZONTAL and I click......... just that it is not horizontal in the view. I see stepping pixels along the element on the screen, and I can measure an angle 0.113d.... between the new element and the original reference element in the DWG reference........
This is driving me nuts!!!! Just when I want to start a project well. I imagine that Revit is trying to be too clever somewhere and eliminate the fraction of an angle, that is in fact important. Is there a setting somewhere that might fix this?
Please help!!
So you have nothing in your file initially then you inserted the CAD survey - correct?
Try the following process:
- you should typically insert the CAD file as this view only, into your site plan. That keeps it 2D which it is.
- Set the view properties to true north
- If the cad file is not true north up, then select it and rotate it until it is true north up.
- Acquire coordinates from the CAD file. This will set your survey correctly.
- Now you can change the view to project north and use the rotate project north tool.
Yes that's right.
I have proceded with your first 4 step which appears to work fine.
Regarding project north, I have a habit (not sure if this is good or not) of leaving it aligned to true north, and simply using the project/true north setting in a plan view just to unlock the free rotation of each plan.....
Please look at the file I have attached. There is a site plan view (oriented true north) and a ground floor plan view aligned to the architectural plan the way I want it. Please note the "horizontal" detail line towards the top of the ground floor plan - This is my problem.
Thanks very much for your efforts
You really have this messed up. Look at the project and survey points attached. You did not do what I suggested. It appears that your rotated your view and did not use the rotate project north tool.
I suggest you start with a clean, new project. Once you mess these up, they are very hard to correct.
BTW - Revit will try to align new objects with existing objects... even if they are slightly askew.
OK, Thanks for your help
project north/true north |
Thu, Mar 17, 2005 at 5:00:19 PM
North Point and project orientation |
Wed, Nov 17, 2010 at 12:38:54 PM
Rotating project north (I've done stuff wrong and need help) |
Wed, Nov 23, 2011 at 11:37:52 AM
Project North and True North |
Fri, Feb 3, 2006 at 6:20:18 PM
Project North & True North |
Thu, Mar 5, 2009 at 5:02:49 PM
Members: | 2115407 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
