16 Users Online (17 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Two Area Plans
Wed, Feb 12, 2014 at 10:05:10 AM | Two Area Plans
cboersen
Revit 2014
I made an Area Plan (gross) and I would like to make another one.  I duplicated the plan view and made a new scheme but all the area boundaries are common between the two plan views.  How do I make two area plan views with different boundries?
Wed, Feb 12, 2014 at 11:10:33 AM | Two Area Plans
You don't duplicate plans to make area plans.  From the Home tag - under the area dropdown, pick area plan and create what you need automatically or by sketching.  Now do the same for the second plan .... you have to uncheck the "do not duplicate existing views" box when when you make your second... or third... or.... plan.
Wed, Feb 12, 2014 at 11:48:58 AM | Two Area Plans
cboersen
I'm with you up to that point.  However, both of those plans use the same Area Boundry Lines.  How do I make a duplicate area plan but with different (no none) Area Boundry lines?
Wed, Feb 12, 2014 at 11:54:45 AM | Two Area Plans
You can use design options.
Wed, Feb 12, 2014 at 12:23:23 PM | Two Area Plans
cboersen
I thought of that but when I try it I get this error
Areas and Area Boundaries are not allowed in Design Options. Make an Area Scheme and an Area Plan for this Option then draw all Areas and Area Boundaries in that view.
I do not exactly understand that error, but "Making an Area Scheme and and Area Plan" is what we talked about above and that just gets me back to using the same area boundry lines again.
Am I reading that error correctly or am I missing something?
Wed, Feb 12, 2014 at 1:42:43 PM | Two Area Plans
I have not had to do what you are trying to do so I'm not sure of what I would do....using sketch lines - not automatic
but I would use two different plans with a view crop..... move the first area lines and areas out of rage a known difference and create the second ones.  You might shift left/right a specified amount to be able to modify later.
Thu, Feb 13, 2014 at 9:52:03 AM | Two Area Plans
cboersen
What I did was create another empty Revit file and link the origial Revit model to it.  Then I created an other area plan with new Area Boundries.  You do have to make sure you uncheck the switch in the "Edit Color Scheme" menu labeled "Include elements from linked files" or the original Area Boundries will STILL show.
new Area Scheme question
Tue, Jun 20, 2017 at 4:11:49 PM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Area Plans for design options
Fri, Jul 21, 2017 at 1:37:36 PM
area plans again?
Wed, Sep 14, 2011 at 9:07:33 AM
Area Plans
Wed, Nov 1, 2006 at 10:03:12 AM
Page generation time: 24.5850
