68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> Roof Ridges not appearing in the correct locations
I added a small roof with a gable and a hip, and the lines of the created valley and hip do not go to the corners of the roof like I would like. I have messed around with the pitch, but it is still not drawing the lines to the corners of the roof. Im using Revit 2014.
Edited on: Tue, Feb 11, 2014 at 4:29:33 PM
Edited on: Tue, Feb 11, 2014 at 4:45:19 PM
We need to see your roof sketch.
Are all of those walls the same height? I'm assuming they are not by the image and that would be your problem.
Non-standard Roof - Surprisingly Difficult |
Mon, Jul 25, 2011 at 9:24:59 PM
Roof plane Ridge, Hip and Valley locations. (Roof bu footprint) |
Wed, Sep 11, 2024 at 7:46:54 PM
Walls not appearing in DWG Export |
Fri, Feb 8, 2019 at 12:16:41 PM
roof issue (even roof valley slopes with uncentered drain locations) |
Wed, Mar 14, 2012 at 12:25:14 PM
Roof not appearing in roof plan |
Tue, Sep 6, 2016 at 1:43:56 PM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
