34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Arch Walls Block View of Struct Posts
Tue, Feb 11, 2014 at 1:27:48 PM | Arch Walls Block View of Struct Posts
rzfx
I'm taking a RVT file from an architect and adding beams/posts to it. However, when I add posts inside the architects walls they disappear due to the walls blocking their appearance. If I hide the walls I can see the structural items I added inside them. It doesn't matter if the architects file is linked, or linked-then-exploded, the walls always block site of the structural items. Does anyone know how to allow the posts appear inside the walls??? Thanks!
Tue, Feb 11, 2014 at 1:39:45 PM | Arch Walls Block View of Struct Posts
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"It doesn't matter if the architects file is linked, or linked-then-exploded" You can't explode a revit project so whatever you are linking in and exploding is not a revit project.
Tue, Feb 11, 2014 at 1:42:24 PM | Arch Walls Block View of Struct Posts
rzfx
Sorry not "explode". I meant to say "ungroup".....
Tue, Feb 11, 2014 at 1:49:28 PM | Arch Walls Block View of Struct Posts
Not ungroup either.  The file should just be linked.
Maybe this is part of your problem.  You need your own file with the architect's file linked into it.  You can then control the visibility of the architect's model seperate from yours.
Tue, Feb 11, 2014 at 1:56:52 PM | Arch Walls Block View of Struct Posts
rzfx
It's a new file with the architectural file linked into it.
Tue, Feb 11, 2014 at 2:07:39 PM | Arch Walls Block View of Struct Posts
So in a view goto VG/Linked Revit/set it to custom/then VG/Model and set the walls as you wish.  Maybe transparent, maybe coarse.... This is all up to you.
Tue, Feb 11, 2014 at 2:10:52 PM | Arch Walls Block View of Struct Posts
rzfx
To review for clarity:
I create a new file. I link the architectural file into it. If my view is on "structural" I won't be able to see the architect's walls, so I change it to "coordination" view. Now the walls appear. I add a column into the wall and it disappears after being placed. I then hide the wall and the column is visible, which proves that the column is visible in that view range. How do I make this column visible in the wall? Thanks.
Tue, Feb 11, 2014 at 2:16:47 PM | Arch Walls Block View of Struct Posts
rzfx
OK it's working now. Thanks for your answers.
We have >2K cols in proj. How can we replace our arch. elements 4 struct. ones
Mon, Dec 12, 2011 at 4:05:12 AM
Combinng sheets from Revit Arch, Struct and MEP into one CD set
Mon, Apr 13, 2009 at 2:40:35 PM
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:37 AM
Linking Arch file into Struct and using Arch groups?
Tue, Jan 18, 2011 at 7:44:19 AM
Problems Copying Walls from Linked Arch Plans?
Wed, Jul 15, 2009 at 4:23:32 PM
Page generation time: 1.9408
