97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window Head / Opening Cut
Fri, Feb 7, 2014 at 8:14:50 PM | Window Head / Opening Cut
chimso
I am wondering if it is possible to have a partial opening cut in a window family along with the full window opening. I have a window which I have created and I would like to recess the exterior head material partially into the wall, but because it is a concave shape, I need to remove the exterior finish of the wall in the area where the header occurs, and was wondering if that was possible.
Mon, Feb 10, 2014 at 7:31:00 AM | Window Head / Opening Cut
To do this, you have to delete the opening cut and add your own void cuts.  Be careful - create your cuts first because they will cut your objects if added afterwards.
This user is online
head height of window
Thu, Nov 3, 2005 at 5:19:15 PM
Actual Window Head height
Thu, Jun 7, 2007 at 5:44:30 PM
Window head & Jamb [ 1 2 ]
Thu, Jun 22, 2017 at 10:32:59 AM
20
window head showing in floor plan [ 1 2 ]
Fri, Apr 29, 2011 at 1:51:23 PM
16
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:50 AM
14
Page generation time: 0.5772
