60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Copylink?
Thu, Feb 6, 2014 at 4:07:44 PM | Revit Copylink?
johnkinder
Is there any way to get an IMAGE (preferably vector) in one step, straight from Revit with No Background Color ( as in transparent) with NO EXTRA STEPS?  I  need this function for droping a 2D Plan View into Power Point Slides so that my boss and coworkers can add color or patterns behind the image.  It would also be nice to have for other programs I may use.
There was a command called "copylink" in AutoCAD that could do exactly this.  Does anyone know how to do the same or something very similar in Revit?
Please don't tell me that you could do this in other programs.  I only sited Autodesks "copylink" command as an example of what I am trying to achieve.  I am not looking for any soloutions involving using paint, photoshop or any other program to remove the white (or whatever color) background as it typically looks dirty if I need to resize it at all later on.  I am looking for a solution preferably within Revit.  5 stars to anyone with the answer.
Thanks!
Edited on: Fri, Feb 7, 2014 at 9:42:47 AM
Fri, Feb 7, 2014 at 7:18:09 AM | Revit Copylink?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What do you mean an image?  Like a rendering?  You can render it with a white background
Fri, Feb 7, 2014 at 9:20:32 AM | Revit Copylink?
johnkinder
For this specif case, we will say I am trying to capture a 2D Plan View from Revit with No Background Color (as in transparent).  I did some research last night and found that a "vector" based image and not a raster would be preferable for this senario.
Edited on: Fri, Feb 7, 2014 at 9:44:31 AM
Revit for Construction Documents [ 1 2 ]
Tue, Jan 24, 2012 at 10:57:39 AM
20
4D simulation in Revit? [ 1 2 ]
Mon, Jan 17, 2011 at 11:27:40 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ]
Thu, Jan 6, 2011 at 3:25:03 PM
18
We are looking for Revit Users [ 1 2 ]
Thu, Mar 31, 2011 at 5:15:25 PM
17
AutoCad vs Revit [ 1 2 ]
Thu, Aug 4, 2011 at 1:58:53 PM
16
Page generation time: 3.7676
