68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> CUSTOM KEY NOTE TAGS/ ROTATING VIEWS IN PLOT SHEETS
2 questions...
First I am trying to create custom keynote tags that we can saved as a family and be able to add text to in a drawing. We have a lot of demise pier options in our centers and while they all have the same tags, the numbers in each vary. Is there a way to create one of these and be able to inport it into the drawing and how?
Also when I rotate a view clockwise or counterclockwise to fit on a titleblock, none of the text in the drawing stays so now we have to flip the sheet, or turn out heads to read it. This includes column numbers in the grid heads, and all of the text in the drawing. Anyway to fix this?
Thanks in advance!
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
"I rotate a view clockwise or counterclockwise to fit on a titleblock, none of the text in the drawing stays so now we have to flip the sheet, or turn out heads to read it. This includes column numbers in the grid heads, and all of the text in the drawing. Anyway to fix this?"
No there is no way Revit will not rotate your text if you rotate the view
Okay thanks anyway. Any information the the first question?
Have you looked at how to create keynotes and keynote legends in your help?
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-1B230C4F-E5AE-4CB6-A468-7F8293D8DF16
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-4ED30197-CE07-477A-A093-6C397DE446CC
Part of your problem is process. There are two ways to rotate a view.
- Rotate a view window
- Rotate view on a sheet.
You want to use rotate view window I think. Open the view, turn on the crop window. Pick that and rotate it. All text and dimensions will stay normal.
Read this topic in your HELP for your tag question:
Annotation Labels
Plot Preview in PDF |
Wed, Feb 22, 2012 at 11:28:24 AM
Need help with tags |
Tue, Apr 20, 2010 at 3:21:03 PM
Revision Clouds and tags on Sheets or in Views? |
Wed, Jan 20, 2016 at 9:36:23 AM
Key Notes Across Divisions. |
Thu, Jan 27, 2011 at 10:07:01 AM
KEY NOTE ABBREVIATION |
Thu, Jun 2, 2005 at 6:07:46 PM
Members: | 2016947 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
