Forums >> Revit Building >> Technical Support >> Door Tags
Fri, Jan 31, 2014 at 7:22:30 AM | Door Tags
rugbybodders
Revit 2013
I have created a door tag using the Vision Panel parameter, which is a 'Yes/No' Visibilty Parameter.
In the label for the tag, I want it to report a 'VP' if the Vision Panel is present, and be blank if the Vision Panel is not present. Is there a way of having an IF statment in the label to enable me to get the outcome I require?
Craig
Fri, Jan 31, 2014 at 7:35:44 AM | Door Tags
3.5 Stars: 401 Votes
You can not have formulas in tags.  You need to make this a type parameter and have a parameter set that is read by your tag and is set as a type.
Fri, Jan 31, 2014 at 7:44:38 AM | Door Tags
rugbybodders
I was thinking of have a second parameter, called VP Present, which could report using an IF Statement. Something like this:
IF (Vision Panel = Yes, "VP" , "  ")
Syntax is wrong though and can seem to get it to work! Can anyone help?
Edited on: Fri, Jan 31, 2014 at 9:19:55 AM
Craig
Fri, Jan 31, 2014 at 8:27:24 AM | Door Tags
A type parameter can not reference an instance parameter so vision panel must be a type.  Otherwise, it looks OK.
Fri, Jan 31, 2014 at 9:56:17 AM | Door Tags
rugbybodders
Syntax doesn't seem to work, as the attached image.
Any thoughts?
Craig
Fri, Jan 31, 2014 at 10:13:56 AM | Door Tags
People need to learn to use Revit's help.....
Your problem is you did not check on the proper syntax in your help under the topic
Conditional Statements in Formulas
where you will find "IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)"
"IF with a text parameter: =IF (Length > 35', “String1”, “String2&rdquoWinking"
Edited on: Fri, Jan 31, 2014 at 10:15:43 AM
Fri, Jan 31, 2014 at 10:27:44 AM | Door Tags
rugbybodders
Any thoughts?
Craig
Fri, Jan 31, 2014 at 10:33:10 AM | Door Tags
Read .... ".... (Note that both the condition and the results are implied.)..."
IF (Vision Panel, "VP" , "  ")
Fri, Jan 31, 2014 at 10:53:57 AM | Door Tags
rugbybodders
Thank you for the help, greatly appreciated.
Craig
Door Tags
Mon, May 12, 2014 at 8:31:35 AM
Accessing Room Data in Door Tags
Mon, Jan 28, 2013 at 9:42:59 AM
Door tags and Door Type ID
Wed, Jul 10, 2013 at 1:40:25 PM
Door and window tags
Thu, Nov 3, 2011 at 8:51:34 AM
Room Window and Door Tags
Thu, Nov 15, 2007 at 9:21:10 PM
Page generation time: 0.4772
