84 Users Online (83 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Graphics glitches after multiple upgrades
Wed, Jan 29, 2014 at 12:08:55 PM | Graphics glitches after multiple upgrades
AnejoDave
I have a project that was started in version 2012 and then upgraded through 2013 and now up to 2014.  Ever since it was upgraded to 2014 I've been experiencing graphics glitches.  Things like overrides working in the morning, not working in the afternoon, not there next morning and back to working again in the afternoon.  Filters are doing whatever they want to do, not what they're supposed to do.  And my favorite - graphics that change at random.
Has anybody else had this problem?  If so, is there a fix or are we stuck with an unstable and ugly project.  The good thing is it's almost done so it'll soon be the contractor's problem.
Use "Hide in View" and you're a nazi terrorist who takes the last beer
Wed, Jan 29, 2014 at 12:17:12 PM | Graphics glitches after multiple upgrades
Have you audited the file?
Do you have the 2014 updates installed?
Did you religiously review the warnings and clean those up as much as possible?
Are all of your graphic card drivers up to date?
Wed, Jan 29, 2014 at 12:21:47 PM | Graphics glitches after multiple upgrades
AnejoDave
Yes
Yes
No - not related to the issue at hand
Yes
Thu, Jan 30, 2014 at 6:24:29 AM | Graphics glitches after multiple upgrades
archigrafix
5 Stars: 4 Votes
We are experiencing also on Revit 2014 update 2 that some visibility settings enforced by templates do not stay permanently applied as they are supposed. For instance we need to constantly switch a certain filter visibility from on to off and back to on to get it to refresh and apply the settings (on the template visibility settings). We also noticed lines above on stairs are turned off everytime we open the revit file, even though it's on on the applied view template.
Edited on: Thu, Jan 30, 2014 at 6:24:53 AM
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Thu, Jan 30, 2014 at 7:38:23 AM | Graphics glitches after multiple upgrades
I have seen some upgrade problems on the past so I won't throw that thought out.  The only solution for that would be to have Autodesk look at the file.  That is a one day turn around typically - on subscription.
Check your templates and make sure they got upgraded correctly.  Maybe one of the settings got dropped.  It sounds like your filter is NOT there.
Thu, Jan 30, 2014 at 9:09:35 AM | Graphics glitches after multiple upgrades
AnejoDave
It's even happening to filters made after the upgrade.  The problem seems to be with the older elements instead of the setting themselves.At least we now know we're not the only ones so it's not our computers causing the problem.
forced upgrades
Fri, Feb 12, 2016 at 9:07:53 AM
controlling/setting Visibility Graphics for multiple Views
Mon, Oct 4, 2010 at 2:22:13 PM
lighting glitches on night scenes
Wed, Aug 10, 2005 at 4:29:35 PM
Revit Architecture 2011 Graphics Glitches
Fri, Aug 6, 2010 at 3:19:19 PM
Linked File upgrades the whole time?
Mon, Jul 9, 2007 at 9:15:52 AM
Page generation time: 2.7616
