Forums >> Revit Building >> Technical Support >> Invisible Topo
0 Posts No Rating |
Im updating projects site and adding in a topo. When i go to add in the topo and place a point the Black square does not attach to my mouse and you cannot even see it. If i click points on the drawing the area will calculate in the properties menu and when i click to complete it will complete but it does not exist and is able to be clicked on. I have checked the visibility and graphics and topo is turned on so I am wondering if anyone has come across this before and what the heck has happened.
0 Posts No Rating |
Also forgot to mention that in properties everything is greyed out.
What Revit? What updates are installed?
0 Posts No Rating |
Revit 2014 Build 20130308_15x15(64)
But I am able to create and modify other topo's in other drawings but unable to create any topo in to update this new drawing.
0 Posts No Rating |
** typo
revit 2014 build 20130308_1515(x64)
2014 has updates - install those first.
0 Posts No Rating |
I think there is something wrong or a setting changed in my 2d view becuase I found my topo in 3d below the building by quite alot . I brought it up to the level of the current floor and it is still not visible on plan (2d).
0 Posts No Rating |
Thank you WWHub I have fixed the issue. The person who had worked on this before me had set the bottom of the drawing way below the actual building and the topo was set to that. and the floors wereset to the footing level of the footings instead of the first floor so when I adjusted the topo to the height of the floor so that it would work with the floor it was still not showing up i figured out that the view plane was seto to see everything on the first floor but the only becase of the thickness of the floor slab did it appear in plan view. Corrected both the floor level and topo level and now it is all visible thank you very much.
Still install the updates .... they fix problems. You should always install them ASAP.
0 Posts No Rating |
ok thankyou I will mention that to my supervisor
