57 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> window with inset parameter
Tue, Jan 21, 2014 at 3:21:30 PM | window with inset parameter
vblevin
Does anyone have or can direct me to a double hung window W/TRIM, and an inset parameter so it will place correctly in a stud wall with stone veneer? Marvin has parameter but no trim. (I'm using Revit2012)
Thanks
Tue, Jan 21, 2014 at 3:54:55 PM | window with inset parameter
I don't believe you will find many, if any.  It would be far easier to add trim to a family that has a setback.  We create our own window and door families because of this issue.
I have not looked at the Marvin window for awhile.  If it works well, then use that and edit it.  Or - create a seperate trim family that will flex and load it into the marvin family and control it there.
Edited on: Tue, Jan 21, 2014 at 3:57:01 PM
Wed, Jan 22, 2014 at 7:44:13 PM | window with inset parameter
dano3d
3.5 Stars: 3 Votes
I created a double-hung window with an "inset parameter". The materials will need some work if you need it for rendering purposes. There are also parameters for optional shutters, optional window grilles, and varied sizes for interior and exterior trim. Note, this was made with Revit version2013. Hope this helps in some way.  Dano3d
Wed, Jan 22, 2014 at 8:00:23 PM | window with inset parameter
dano3d
3.5 Stars: 3 Votes
Sorry about that... I noticed you're working with Revit-2012. Luckily the job I made it for was done last year so I had an older version of it. Don't even get me started on the disappointment of not being able to save backwards to older versions of Revit. Hope you have better luck opening this window family. We'll both need to upgrade to Revit-2014 soon!  Dan3d
Thu, Jan 23, 2014 at 8:57:51 AM | window with inset parameter
vblevin
Your right WWHUb (I'm lazy).
Thanks for the window dano3d.
Thu, Jan 23, 2014 at 9:23:23 AM | window with inset parameter
vblevin
Awesome window dano3d!
Much appreciated.
Thu, Jan 23, 2014 at 9:41:01 AM | window with inset parameter
dano3d
3.5 Stars: 3 Votes
I'm glad it can potentially help you. I've attached a double unit that was created for the same project. Good luck with your job.  Dano3d
window inset parameter for the Revit 2017 OOTB windows
Thu, Mar 22, 2018 at 8:55:22 AM
Embedded Windows
Wed, Jan 4, 2006 at 4:52:29 PM
Wall Type with inset coursing (Revit 2017)
Tue, Aug 15, 2017 at 10:02:46 AM
window not cutting joined roof
Mon, Mar 6, 2017 at 4:23:50 PM
cabinet inset disappears.
Mon, Jan 23, 2017 at 7:15:41 PM
Page generation time: 26.1508
