36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Masking region transparency
Mon, Jan 20, 2014 at 11:40:36 AM | Masking region transparency
ryantcook
Is there any way to set a transparency for a masking region? I know for filled regions you can select the background to be opaque or transparent, however you cannot fine tune the percentage of opacity, like what is possible with Autocad.
I am trying to fade back the interior of my building to highlight the hardscaping on the sheet. I would like the interior walls and furniture to be faded back to achieve this..(and I do not want to override visibility graphics for the elements either, because of existing dependent plan views on other sheets)
Thanks
Mon, Jan 20, 2014 at 11:59:22 AM | Masking region transparency
3.5 Stars: 395 Votes
There is no such setting in Revit.
Why would you not use the over-ride graphics "IN VIEW"....Doesn't affect other views except dependent and your masking region would affect those as well.  Perhaps you should be using a different view rather than one that has dependent views.
Mon, Jan 20, 2014 at 12:36:29 PM | Masking region transparency
ryantcook
I was trying to use a masking region so that 'hopefully' I could easily adjust the transparency values on the fly as I experiment with the line weights out of the printer. I was trying to avoid override 'in view' because the floor plan has lots of elements that would have to be selected and changed everytime if I wanted to experiment with opacities 25%, 50% and 75% for example. Whereas with a masking region, I was 'hoping' to just have the one element to select and change settings.
Thanks for your advice, I will duplicate with detailing instead of as a dependent!
Also, im not really a revit newbie, just a revit city forum novice. Is this thread correctly placed?
Mon, Jan 20, 2014 at 1:02:34 PM | Masking region transparency
I moved the thread but that wasn't critical.
We use worksets and filters to help control things like this.  Your interior walls could be on a seperate workset from the exterior shell and furnishings should be a controllable category by themselves anyway.  No reason to do these one at a time.
Filled Region / Masking Region Transparency override
Fri, Nov 4, 2016 at 11:55:09 AM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region
Sun, Sep 14, 2014 at 2:36:26 PM
Masking Region doesn't seem to be masking
Thu, Mar 17, 2016 at 10:59:36 AM
Page generation time: 1.8290
