41 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> visibility formula
Wed, Jan 15, 2014 at 4:59:53 PM | visibility formula
edf8583
I have three elements (overlapping geometry) with the visibility controlled with yes/no conditions based on a numerical value from another parameter.  <4 checks one box and therefore turns one on, >6 checks the other and turns another on.  How would i write a formula to have the last one checked and come on if the value falls between 4 & 6?
Wed, Jan 15, 2014 at 10:40:57 PM | visibility formula
CDWdavid
5 Stars: 5 Votes
You may use "IF" command.
You can open a door family in the thread below and see what I did, which I was using "IF" to control the visibility.
http://www.revitcity.com/downloads.php?action=view&object_id=11969
Thu, Jan 16, 2014 at 11:02:09 AM | visibility formula
TKennedy
4 Stars: 7 Votes
Try AND. The will set the parameter to True only if both conditions are met.
Thu, Jan 16, 2014 at 2:26:26 PM | visibility formula
edf8583
thank you CDWdavid but I think what I want is more simple.  I'm trying TKennedy's advice but getting an error using "yes" as a value? There is a pic of my parameters attached
Thu, Jan 16, 2014 at 3:03:10 PM | visibility formula
TKennedy
4 Stars: 7 Votes
Yes/No parameters are a little odd in that you don't need to say Yes/No, True/False, etc. If the condition is true, the parameter is set to "on". In your case the IF condition is redundant, so your formula is simply 'and(not(GreyVisible), not(BlueVisible))'. Revit will read that as "if GV is not true and BV is not true, turn Y on". Unless the help file has been updated since I first learned about Revit booleans, that's not spelled out very clearly.
Edit: I misread your formula the first time, it would have worked backwards. Fixed now.
Edited on: Thu, Jan 16, 2014 at 3:05:31 PM
Thu, Jan 16, 2014 at 3:28:44 PM | visibility formula
edf8583
Thanks TKennedy!
That makes a lot more sense now!  Works perfectly Smile
Opposite formula
Fri, Jun 20, 2008 at 3:46:44 AM
Help with formula needed
Wed, Apr 9, 2014 at 10:47:20 AM
Visibility Formula in Family Parameters
Mon, Apr 24, 2017 at 6:06:35 PM
Visibility Parameter Formula based on 0.5m Lengths
Tue, Sep 6, 2011 at 4:59:07 AM
Using schedule total in formula?
Fri, Apr 4, 2014 at 10:29:50 AM
Page generation time: 0.4055
