65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Resetting/fixing the analytical model (Revit Structure 2014)
Wed, Jan 15, 2014 at 8:11:05 AM | Resetting/fixing the analytical model (Revit Structure 2014)
abusementpark
Hello,
We had a model of a steel structure built in REVIT and needing to adjust locations of a lot of framing and shift several gridlines.  Well, we didn't realize until a good while after we made the changes that for some reason the analytical model did not follow these changes.  Thus, as it currently stands,  a lot of analytical nodes and members do not match their physical counterparts in the model.  In some locations, things became disconnected along with other errors.
Going to through and manually adjusting has proven to be a bear.  Is there anyway for you completely scrap the current analytical model and have the program generate a completely new one that precisely matches the current physical model??
Thanks!
Wed, Jan 15, 2014 at 8:56:49 AM | Resetting/fixing the analytical model (Revit Structure 2014)
gebber
gebber Avatar
5 Stars: 4 Votes
Had a similar problem a few weeks back.
If possible try to align the analytical line
Now you probably notice the analytical line is aligned with the profile but both are disconected.
Align again and it's solved.
I gues jus a strange bug?
anyhow when looking in to this problem I ran into this video wich might come in handy next time you'll have to create a similar structure.
http://www.youtube.com/watch?v=aXQ4vR9HanY
good luk
Problems with the Revit Structure Analytical Model
Fri, Apr 20, 2012 at 2:43:37 PM
Analytical Lines creates blank space in schedule in revit str 2014
Thu, Sep 11, 2014 at 8:10:31 AM
physical to analytical model Conversion Mechanism and Etabs
Sun, Apr 5, 2009 at 8:49:35 AM
Analytical Modeling Issues
Wed, May 14, 2008 at 12:03:15 PM
Revit 2017 No analytical model for curved wall
Fri, Feb 17, 2017 at 4:59:56 PM
Page generation time: 1.8887
