54 Users Online (53 Members):
Forums >> Community >> Newbies >> Ribbon Issues
0 Posts No Rating |
Starting on a new computer at work, I have run into issues with the ribbon that i have not experienced on my computer or the school computers. Whenever I try to edit something whether it be a floor boundary, topo surface, mass profile, or anything similar, after selecting the desired object, the 'Edit' option will appear on my ribbon however none of the drawing tools will appear until I cycle through all ribbon panel button options.
Basically, if I want to edit something once I select it and click 'Edit', I must click the cycle tabs button 4 times before the drawing tools will appear for me to use. The same is true for when I try to 'Finish' or 'Cancel' an edit, I must cycle through before the check or X will appear.
Thanks for your help
You don't tell us what Revit you have installed and what updates are installed. This is most likely an update issue. The updates are list under the question mark pulldown on the right - "about".
0 Posts No Rating |
I'm working with Revit 2013, I just downloaded release 3 from the autodesk website and restarted revit. works like a charm now, thanks!
ribbon issues |
Thu, Aug 27, 2015 at 10:14:04 AM
Revit 14 issues |
Thu, Mar 13, 2014 at 9:43:51 AM
13
Ribbon for Revit |
Sat, Aug 29, 2009 at 2:09:53 AM
Ribbon tabs 2011 |
Wed, Nov 23, 2011 at 2:08:46 PM
Ribbon Windows |
Thu, Jan 19, 2006 at 4:41:53 PM
Members: | 2030875 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
