71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> moving the model
Tue, Jan 14, 2014 at 8:53:06 AM | moving the model
PerferAutoCad
What is the best way to move the entire model 84'-0" north?
Tue, Jan 14, 2014 at 9:17:32 AM | moving the model
Why?  .... in relation to what?....  There may be better options.
Tue, Jan 14, 2014 at 11:37:22 AM | moving the model
PerferAutoCad
The architect moved the building 84' north.  I have to move my structural model
Tue, Jan 14, 2014 at 12:06:43 PM | moving the model
There are several options here and it's too bad the architect actually moved his model.
Watch this video:
http://www.youtube.com/watch?v=BigvY4LT-RI
Sun, Jan 19, 2014 at 10:36:13 PM | moving the model
PercIII
I have a similar issue where one of three buildings will be moved a few feet on the site. Masking regions and detail lines were created in the elevation and plan sheets based off the existing location of this particular building. I want to avoid recreating or moving each instance of a line or region to match the new location a few feet away. Would manipulation of the survey and project points be the best method of doing this?
Thanks,
Jordan
Mon, Jan 20, 2014 at 7:50:42 AM | moving the model
I have no really good answer for you.
Because you are talking about 2D elements in views, you don't actually want to move your model in your project.  You want to move how it is referenced.  If the project and its relationship to other models was set up using the project location, then maybe that will work.  Sometimes you just have to move the other links in relation to your model but then your consulants will have to move your link in their model.
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:03 AM
Devices Moving IN Model
Tue, Dec 6, 2011 at 1:47:26 PM
Changing Level Elevations without moving the Model?
Tue, Sep 4, 2012 at 5:58:04 PM
Moving a linked Revit model
Thu, Nov 21, 2013 at 3:58:00 PM
Moving project to align with Revit Structural File
Mon, Apr 22, 2013 at 7:22:13 AM
Page generation time: 2.2709
