35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> invisible objects!!!!!!!!
Mon, Jan 13, 2014 at 12:45:31 PM | invisible objects!!!!!!!!
1 Stars: 1 Votes
Hi.
I need some trees in my project.i can see them in 3D Views!!! i check VG(visible Graphics) all the items are marked!
what shoud i do? i should do render soon.
Mon, Jan 13, 2014 at 12:48:53 PM | invisible objects!!!!!!!!
Sorry but your question is not clear.  You said " i can see them in 3D Views".... so what's the problem?
Mon, Jan 13, 2014 at 3:07:09 PM | invisible objects!!!!!!!!
1 Stars: 1 Votes
Sorry!
I wanted to say i can't ...
Mon, Jan 13, 2014 at 3:21:32 PM | invisible objects!!!!!!!!
OK ... So are they in your project?
What Revit version? and What is your last update?
What trees are you using?
Revit trees don't always show in simple 3D views - depends on Revit issue.
Mon, Jan 13, 2014 at 4:20:58 PM | invisible objects!!!!!!!!
1 Stars: 1 Votes
Revite 2013The trees that are in the revite!i didn't download them.i can see them in the plan but in render view and 3d i can't see them!and in another project they are in 3d view but when i render,they don't exist!
Mon, Jan 13, 2014 at 4:23:39 PM | invisible objects!!!!!!!!
1 Stars: 1 Votes
Thank you for your attention.
INVISIBLE WALL
Wed, Aug 15, 2012 at 4:18:15 PM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:19 PM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:49 PM
Rendering an invisible wall.
Sun, Apr 24, 2011 at 12:01:50 PM
Making The Invisible Visible
Thu, Aug 19, 2010 at 4:10:35 AM
Page generation time: 1.5965
