42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> view title is hidded
Fri, Jan 10, 2014 at 10:04:24 AM | view title is hidded
Kathe33
I am using 2013 Revit. the view title is hidden and the unhide element is grayed out. I'v looked at visability graphics and it's on. Any idaes ?
Fri, Jan 10, 2014 at 10:16:35 AM | view title is hidded
How do you know that it's hidden?
I can't hide a view title but I can set the view to No Title.  Click on the view and see if that is what was done.
Fri, Jan 10, 2014 at 10:17:43 AM | view title is hidded
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
View Titles cannot be hidden but they can be set to none...Click on your view on the sheet and in the Properties type selector select a Title Type
Fri, Jan 10, 2014 at 10:20:42 AM | view title is hidded
Kathe33
checked all that, the only way i can see it is to turn on view hidden on the sheet.
Fri, Jan 10, 2014 at 10:25:26 AM | view title is hidded
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I guess I was wrong, if you click on the actual view and hit hide element it will hide just the View Title (sotra weird).  With the hidden elements turned on click on the view and click Unhide Element.. see image
Fri, Jan 10, 2014 at 10:25:53 AM | view title is hidded
I'll be darned.  You can hide a view title but you hide it by clicking on the view - not the title.  You un-hide it the same way.  Show the hidden elements and click on the view - then un-hide elements.
Fri, Jan 10, 2014 at 10:26:49 AM | view title is hidded
Teafoe .... you beating me to the much too often....<grin>  Have at it.
Fri, Jan 10, 2014 at 10:27:33 AM | view title is hidded
Kathe33
unhide is grayed out?
Fri, Jan 10, 2014 at 10:35:59 AM | view title is hidded
Click on the view - NOT the red title.
Fri, Jan 10, 2014 at 11:01:34 AM | view title is hidded
Kathe33
that did it thank you so much, I have never seen it do that before could I have inadvertedly turned it off.
Moving View Title
Sat, Mar 6, 2004 at 9:46:28 AM
Modify View Title
Wed, Jun 11, 2014 at 7:37:29 AM
11
Revit View Title with buble on right side
Thu, Mar 11, 2010 at 10:37:28 AM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
View Title for Legends
Fri, May 6, 2016 at 4:27:58 PM
Page generation time: 1.3030
