Forums >> General Discussion >> Revit Project Management >> Transfer Project Standards not working
18 Posts No Rating |
Transfer Project Standards does not seem to be working.
I updated the template in this case by changing the object styles. For example I changed the value of stairs in section from a 1 (which is the factory default) to a 4. This is all fine, except that when I opened up my project, which was started from the previous template before the change, and went to "transfer project standards" from the template file, I went through the process and the object styles did not update but stayed the same. I tried several times, making sure to save the updated template file, to see if this would make a difference, and still no updated standards. Any idea why this is the case? Is this a bug in 2013? I dont understand this seems like a simple task.
I have not tested this in 2013.
Have you got all 3 2013 updates installed?
Yes I need to upgrade to Release 3. I will let you know if this fixes the problem.
I also have 2014 installed on my machine but I want to stay in 2013 for the time being.
Oh, wait, Revit LT 2013 only has up to Service Pack 1 and the standard Revit 2013 releases do not function with LT. I know - strange that I am working in LT but that is just what I have right now. Did they forget to include this upgrade for 2013?
I am switching everything over to 2014 i will check the Transfer Project Standards issue when I get there.
TRANSFER PROJECT STANDARDS??? |
Thu, Jan 8, 2009 at 1:27:38 PM
transfer project standards - line weights not transfering |
Mon, Jan 11, 2016 at 11:20:54 PM
Transfer Project Settings |
Fri, Apr 13, 2007 at 4:56:33 PM
Transfer Project Standards - 'Filter' colour fills not transferring |
Fri, Jun 27, 2008 at 10:12:20 AM
Transfer Project Standards |
Tue, Sep 22, 2009 at 11:30:39 AM
Members: | 2099155 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
