71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Nested Parameters?
Tue, Jan 7, 2014 at 12:28:27 PM | Nested Parameters?
jordanjoyful
I want to set up a schedule for kitchen appliances, so far all the type marks, families, model numbers, etc. work just fine. On the AutoCAD schedule I'm duplicating some electrical info is under a heading "LOAD." How do I make this appear in Revit? I was working with project parameters.. thinking the might have to be nested somehow?? Any ideas? Thanks for your help!
CAD schedule is attached.
Tue, Jan 7, 2014 at 12:31:49 PM | Nested Parameters?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There is nothing attached but why are you talking about AutoCAD schedules?  You need to add the "LOAD" parameter to your family in Revit.  Look in your help under Shared Parameters.
Tue, Jan 7, 2014 at 2:01:27 PM | Nested Parameters?
jordanjoyful
I was trying to recreate a schedule that I made in CAD, now that I've switched over to Revit. (I attached it here, so you can see)
I figured it out actually. In order the categorize or group the parameters I created all the project parameters (shared isn't the best in my case, because some of it will be filled in by hand) then in the schedule I selected the parameters that needed grouping. For example volt, hp, kw, amp and then selected "group" on the modify schedules tab. This creates a heading above the selected cells that can be filled in I called it LOAD. I repeated this process to group different cells and groups of cells under general, electrical, plumbing headings.
Nested Families and System Parameters
Fri, May 8, 2015 at 9:47:42 AM
Scheduling shared parameters of nested famiies?
Sun, Apr 26, 2009 at 1:56:13 PM
Nested family parameters
Mon, Aug 3, 2015 at 12:12:55 PM
Nested family: no option to choose the little button
Mon, Jul 27, 2015 at 9:11:38 PM
Creating nested Family Parameters
Fri, Jun 26, 2015 at 3:52:29 AM
Page generation time: 0.4497
