46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Manifestation for glazing
Greetings,
I am trying to create a line type/style for glazing manifestations that will meet standard UK building regs requirements. That being a line type comprising 50mm dia circles placed at appropriate centres. The trouble being that Revit will only allow me to create a line type using dots, dashes and spaces which will not display appropriately.
I'd rather not have to manually draw and space 50mm dia circles on an elevation and then overide the visibility to make that semi-transparent.
I am using Autodesk Revit 2014.
Any guidance please?
Many thanks,
CM.
You can create a line based detail component to do this. There is one in the uploads but I can't remember the name. A copy is attached.
Here is one that I had created also. Very similar to WWHubs
http://www.revitcity.com/downloads.php?action=view&object_id=12871
Thanks guys, I've managed to take these as a starting point and come up with a version that uses capital 'O' instead of a 50mm dia circle. At 1/20 its about the same size and it spaces as required.
Preferably I'd use a 50mm dia circle but I did try replacing the line text with a line circle but was unsuccessful.
Many thanks,
CM.
Curtain system > glazing panel matherial |
Mon, May 28, 2012 at 1:02:14 PM
Problem with glazing and wall alignments |
Thu, Jan 24, 2013 at 10:16:59 AM
Tell me again how to make "sloped glazing" look like metal roofing? |
Wed, Jun 11, 2008 at 9:43:34 AM
Sloped Glazing - version 2010 |
Tue, Apr 8, 2014 at 12:26:35 PM
Can't delete Glazing or System panels in Revit Structure |
Wed, Apr 17, 2013 at 9:57:51 AM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
