87 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Detail View Question - Cannot see columns in a medium or fine view
Mon, Jan 6, 2014 at 2:30:18 PM | Detail View Question - Cannot see columns in a medium or fine view
kathey1
Please see attachments, I'm in a elevation and I have added a detail section through the wall and columns. When the I go to the View I can see the columns in the course view but when i switch it to medium or fine the columns disappear.
Can any 1 tell me why this happens ??? and also are detail sections supposed to be used this way ??
Mon, Jan 6, 2014 at 2:37:31 PM | Detail View Question - Cannot see columns in a medium or fine view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you cutting your elevation to show a floor plan view? This is not good practice.  Just create a plan view and you should have no problems seeing your columns.  Then from your plan view you can create sections and elevations.
Mon, Jan 6, 2014 at 4:25:34 PM | Detail View Question - Cannot see columns in a medium or fine view
kathey1
i thought this was just another way to use detail views. What is the reason i cannot see the columns ?
Tue, Jan 7, 2014 at 8:45:01 AM | Detail View Question - Cannot see columns in a medium or fine view
3.5 Stars: 391 Votes
I have no problems cutting a plan section from an elevation view.  Did you cut the section and then rotate it?
Tue, Jan 7, 2014 at 9:31:59 AM | Detail View Question - Cannot see columns in a medium or fine view
CHECK THE VISIBILITY SETTINGS IN YOUR FAMILY - SEE ATTACHED
Fri, Jan 10, 2014 at 3:09:37 AM | Detail View Question - Cannot see columns in a medium or fine view
kathey1
ive checked the medium view in the column family and still it doesnt seem to show up in the view. Very confusing ??
Fri, Jan 10, 2014 at 7:35:02 AM | Detail View Question - Cannot see columns in a medium or fine view
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is this a custom column?  Try using an OOTB column and see if you are having the same problem.
Fri, Jan 10, 2014 at 7:39:02 AM | Detail View Question - Cannot see columns in a medium or fine view
You will have to load your family because the stock family works ok.
Also check your VG.
Mon, Jun 11, 2018 at 12:52:34 PM | Detail View Question - Cannot see columns in a medium or fine view
pmartini2012
I am having this same problem but I haven't seen a response from the originator showing their problem was resolved.  To create a new plan view for every one of my working views is not a viable option.  As described in the original post, the views are created from elevation views and in course view, the structural columns are visible.  When changed to medium/fine, they disappear.  It is an incredibly frustrating experience.  I am not looking for a workaround ("Create a plan region from your plan view instead").  Does anyone know what the solution is?
Mon, Jun 11, 2018 at 3:18:32 PM | Detail View Question - Cannot see columns in a medium or fine view
Did you follow through this thread?  The problem may be your family settings as I explained earlier.  Please give more information using images.
Mon, Jun 11, 2018 at 5:41:57 PM | Detail View Question - Cannot see columns in a medium or fine view
pmartini2012
Hi Hub, yes, I did follow through with the thread--I would not have posted otherwise.  The original poster did not respond that their issue was resolved so presumably the original poster also went through the thread and was not able to resolve their issue.  My only possible conclusion right now is that it might be the family, but not exactly the issue you might think it is.  I tinkered with the visilibility settings of the geometry (Course/Medium/Fine) in the family itself to no avail.  Interestingly enough, the geometry whose visibility is set to course in the Structural Column family is visible in the project, but that piece of geometry is set to turn off and another is set to turn on (the geometry that more closely resembles the HSS member) when I set it to Medium/Fine, but this isn't happening in the project after I update the family and import.  I can't figure out why.
I ended up setting the view to Medium, but then using VG to turn my Structural Columns to Course, so that my columns reappear.  It's so strange.
Thu, Aug 16, 2018 at 12:50:29 PM | Detail View Question - Cannot see columns in a medium or fine view
inventomatic
I have a user with the same issue. From and elevation view, we've cut a section looking down a column.
In the section view, the column shows up in coarse mode only. The beams connecting to it show up fine.
We've tried to change columns, cut new sections, experimented with section depths, etc. Nothing.
We're using Revit 2018.3.
Coarse, Medium, and Fine Settings
Wed, Dec 28, 2011 at 12:27:19 PM
Walls – Coarse, Medium and Fine or...
Thu, Oct 8, 2009 at 3:19:49 PM
Fine, medium, course view option not available!
Mon, Mar 10, 2014 at 9:52:32 AM
EDITING CABLE TRAY APPEARENCE - FINE DETAIL IN CORSE DETAIL VIEW
Thu, Aug 12, 2010 at 10:47:33 AM
Problem with 'Coarse' & 'Fine' view options
Thu, May 16, 2013 at 2:07:40 AM
Page generation time: 4.0317
