101 Users Online (100 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
Tue, Dec 31, 2013 at 2:13:29 PM | Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
deliamicaela
This is my first project working in Revit 2014 and the transition has been seamless until I tried to render in Cloud.  I'm getting the error "A problem Occurred, the file could not be translated. -1" when I try to send to cloud.  I have SP1 installed which from other forums seems to be the fix, but that did not work.  Another answer I found was to Check that my user name didn't have any odd characters which is doesn't.  If anyone else if getting this error or knows a solution I would greatly appreciate a response.  Since its NYE and I would like to get this rendering done today and I find it odd that no other fixes have been posted even tho this problem has been documented for months on the Autodesk 360 forum.
Tue, Dec 31, 2013 at 2:32:34 PM | Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There are 2 service packs for 2014, download them both first and see if that fixes your problem
Tue, Dec 31, 2013 at 3:32:56 PM | Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
deliamicaela
Thanks for your quick response.  I have to wait for my IT person to install the Update Release 2 so that will have to wait till Thursday.  Ugh...  I'll let you know if that works.
Thu, Jan 2, 2014 at 12:00:49 PM | Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
deliamicaela
That fixed the problem.  Thank you!
Render in Cloud Problem
Fri, May 24, 2013 at 8:19:23 AM
A serious error has occurred. It is strongly recommended that you use Save As to
Fri, Oct 3, 2008 at 7:52:58 AM
Rendering Via Cloud
Tue, Apr 15, 2014 at 1:58:03 PM
Cloud Rendering - panoramic image
Sat, Jan 26, 2013 at 5:50:19 AM
Rendering in cloud
Fri, Jan 6, 2017 at 7:34:57 PM
Page generation time: 3.4866
