71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> How to Export Room Tag Names and Areas to different layers in Autocad?
Fri, Dec 27, 2013 at 4:25:31 AM | How to Export Room Tag Names and Areas to different layers in Autocad?
pleojera
pleojera Avatar
Hi,I am a newbie from Turkey, working as an architect. SmileHere is my question. I hope you can help me out. We are working on a bilingual project. Unfortunately, company we are working for is not using Revit. They are asking us to export different languages in room tags to different layers in autocad, so they can turn on/off when they want.Is there any way to make this happen?And, ain addiation, what is the best solution to layer management in Revit Exports? I am open to suggestions.Thank you for now!
Fri, Dec 27, 2013 at 7:46:20 AM | How to Export Room Tag Names and Areas to different layers in Autocad?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you read about layer maping in your Help?
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E0B73981-9496-43CD-A358-581FEF3A3008
Sun, Dec 29, 2013 at 2:26:47 PM | teafoe5
pleojera
pleojera Avatar
Quoting teafoe5 from 2013-12-27 07:46:19
Thank you! Yes, I have. But it just allows you to control the layer name/color etc. i want to choose and set the layer of a tag member. Like "Area" to "Tag_Area" Language1 to "Tag_Lang1" Language2 to "Tag_Lang2".  But instead, it is exporting all tag family members (area, name, floor finish, ceiling finish etc.) into one layer as a block.Am i missing something?
Mon, Dec 30, 2013 at 2:03:50 PM | How to Export Room Tag Names and Areas to different layers in Autocad?
RevitMaestro
you can add a new object style within the room tag family.  go to:
manage > object styles > modify subcategories > new
create as many sub-categories under room as you wish.  then, when you load family into the project, the subcategory will appear in the project and when you export you can set that sub category to a new layer name.
however, this only applies to linework, and labels cannot be assigned to a sub category for some reason (that I know of, anyone?), so there is no way to separate different labels to different layers,  maybe this could be an upgrade for revit 2015?
I think the easiest thing would be to create a duplicate floor plan and change the room tag types to show language B within that view.  export.  open in cad and isolate layer.  change the layer name and paste the language B tags into the original export.
Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 2:05:15 PM
AIA Standards- Revit to AutoCAD layers
Thu, Feb 1, 2007 at 12:50:30 PM
DWG Export Mapping File - Export Family Names
Mon, Nov 30, 2009 at 9:17:22 AM
Export fills to layers
Fri, Sep 11, 2009 at 11:51:48 PM
Room Names for Room Tag List
Wed, Feb 24, 2010 at 9:36:06 AM
Page generation time: 2.1221
