65 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Lines color legend
Tue, Dec 24, 2013 at 8:07:20 AM | Lines color legend
solidsnakeala
HI, I am using revit 2014,
Is there somehow anyway to make a color legend for lines?. I mean I am making thick colored lines and i want a legend that refers to each line's color .
Please see the attached picture. i want something like it
Thank you ,
Tue, Dec 24, 2013 at 8:16:02 AM | Lines color legend
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Take a look at this thread and some of the similar threads below it for how others are doing their fire rated walls and legends
http://www.revitcity.com/forums.php?action=viewthread&thread_id=7662
Tue, Dec 24, 2013 at 8:32:17 AM | Lines color legend
solidsnakeala
teafoe5: I have taken a look at the thread . but this is not what i want. because they are all talking about how to make the wall fire rated ... but my issue is not about how to show the wall it is about how to make a color legend for linetypes.
Thank you,
Tue, Dec 24, 2013 at 8:50:53 AM | Lines color legend
What would you have done in CAD?  A filled region?....
Tue, Dec 24, 2013 at 9:02:08 AM | Lines color legend
solidsnakeala
actually , the first picture is a pdf file that i received . and i have to do it on revit, and what i've done is making new line-styles. see the attached pic
Tue, Dec 24, 2013 at 9:03:28 AM | Lines color legend
solidsnakeala
i just want to know if there is a way to make color legend for the line-styles or no.. ((like the rooms))
Tue, Dec 24, 2013 at 9:08:36 AM | Lines color legend
Let's not waste any more time here.   This is foolish.
What is a legend?  It is a representative of the item and text you add.  So for your legend component - draw one of your colored lines and add the text in a legend view.   Obviously, the line will be too narrow so use a filled region with that same color - just like you did in CAD.
Tue, Dec 24, 2013 at 9:15:47 AM | Lines color legend
solidsnakeala
I know this . but my question was is it possible  to have an auto color legend like the rooms legend ((Look at the attachement))??????
Tue, Dec 24, 2013 at 9:35:03 AM | Lines color legend
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No it will not be automated and its not a very good process.
Tue, Dec 24, 2013 at 9:36:25 AM | Lines color legend
You are not doing an area or room legend, are you?  Revit has those two only.  All other legends, you must create.
Please read this topic in your HELP:  Legend Views
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:39 AM
Can I have all my areas on drawing but only few values on Color fill legend?
Tue, Oct 30, 2018 at 7:32:27 AM
Area Legend not showing
Fri, Mar 14, 2014 at 1:00:18 PM
Color Legend Disappears
Fri, May 15, 2009 at 10:31:14 AM
color fill legend dosent show all the types/colors
Fri, Sep 11, 2009 at 12:45:29 PM
Page generation time: 1.1157
