33 Users Online (32 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> tags for windows
Sun, Dec 22, 2013 at 9:30:00 AM | tags for windows
idraw38
I use revit architecture 2011 and am having trouble getting the marks
I have assigned to windows to show up in the window schedule..
The mark shows up in the properties dialog and on the window tag.
What am I missing. The scheduled fields show “mark” as the first
item. The type marks show up in the window schedule.
Mon, Dec 23, 2013 at 7:31:38 AM | tags for windows
3.5 Stars: 395 Votes
You can set up a tag to read either the type mark or the instance mark and you can set your schedule to read either.  The process is up to you, just be consistent.
Mon, Dec 23, 2013 at 9:48:25 AM | tags for windows
idraw38
I gues then the real question is: What dialog do I use to get the schedule to real the instance mark?
Mon, Dec 23, 2013 at 10:02:38 AM | tags for windows
Edit the window tag and change the reference to "mark" instead of type mark.  Save the tag with a new name and load into your project.
Mon, Dec 23, 2013 at 5:54:08 PM | tags for windows
idraw38
I select a window tag from the drawing, then edit family, then I get a sample tag but where do I change the
reference?
Tue, Dec 24, 2013 at 7:41:04 AM | tags for windows
You need to spend some time learning family fundamentals.
Sat, Feb 15, 2014 at 5:37:39 PM | tags for windows
idraw38
I read everything about families. I have another drawing that looks exactly like your attachment. The window schedule reads the mark. The current drawing with the problem appears to be exactly like the other drawing but the window schedule will not show the window mark in the mark column. I've tried everything to get this to work.????
idraw
Sun, Feb 16, 2014 at 12:04:54 PM | tags for windows
Look at the schedule...You set what mark to read there.
Mon, Feb 17, 2014 at 9:29:54 AM | tags for windows
idraw38
The scheduled fields are set up with "mark" at the top. If I select a window, e. g., the one with the window tag 101, it shows up in the properties dialog as mark "101". Yet when I go to the window schedule the "mark" column is blank
I tried setting up a new from scratch drawing, drew a wall, added a door and a window. It worked fine if this helps solve the problem.
idraw
Mon, Feb 17, 2014 at 10:03:33 AM | tags for windows
Did you read my very first answer?????  NOT
Please tile your view so you have your schedule and a view with the tag up.  Now, change the mark in the tag.  What happens in the schedule>  Now click on the window and under type, change the type mark.  What happens?
Fri, Feb 28, 2014 at 4:28:37 PM | tags for windows
idraw38
Yes. The window schedule is set to read the instance mark listed in the properties dialog. The window tag is set to read "mark". If I change the mark in the tag, nothing happens because the mark column is blank. If I change the the type mark, nothing changes in the schedule. The door schedule appears to be set up the the same as the window schdule and it works fine.
Sorry I can't figure this out. I started another drawing by drawing a wall and putting in a window and the schedule works OK.
idraw
Fri, Feb 28, 2014 at 9:47:02 PM | tags for windows
Warchitect
4 Stars: 5 Votes
make sure, after you loaded the new tag into your drawing that you select the existing ones on the plan to be the new family type. if you renamed a new family out of it... Hub has it right though, once you open the family, select the text and make its parameter type the one you want. save again renaming it (so you have both). load into project, and set all the tags to be that type. Ive done this too, and you just got to do it once and it will act like the door schedule you like. I personally don't know why it doesnt act that way now.... but HUB is also right in that I have used both methods now. Though I like the way the door schedule works too.
edit. also make sure the window schedule has the right list fields now too.
Edited on: Fri, Feb 28, 2014 at 9:48:17 PM
Tue, Mar 4, 2014 at 7:58:45 AM | tags for windows
#13
idraw38
In the window schedule properties dialog under available fields there are two listings for "mark". One is the correct one and reads the "mark" of the window. The other one gives a dimension. I have no idea how it got in the fields. I waw choosing the wrong one.
idraw
Tue, Mar 4, 2014 at 11:51:51 AM | tags for windows
#14
Warchitect
4 Stars: 5 Votes
Cool. keep your window scheuls simple at first.
sometimes I have just the mark, height and width, and a comments field I type in the name, like casement, or fixed...
you can type in whatever you want. makes it easy to update and keep on top of. then if you need to make the schedule more complex as you get to CD's
Windows placed in 3d view don't show tags in plan.
Fri, Nov 20, 2009 at 12:47:38 AM
Window Tags not working
Fri, Sep 24, 2010 at 7:30:45 PM
Changing Window Tags
Thu, Jan 7, 2010 at 10:54:27 AM
Door and Window Tags
Wed, Jun 19, 2013 at 12:36:11 PM
Beam & Column tags
Tue, Jun 14, 2005 at 4:48:53 AM
Page generation time: 0.9338
