29 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Floor finish issues
Thu, Dec 19, 2013 at 11:36:16 AM | Floor finish issues
zakazai
Respected Revit Masters
i got an issue with flooring
i have attended many trainings in revit, but still i have a doubt regarding floor finishing with tiles.
i would like to know, how i can put ceramic tiles in various sizes in a room, may be 2-3 different sizes of tiles comes together. or i may need to cut some patterns on the floor that is filled with marbles, like water jet cut designs.
i know how to add material but i am confused to make it tiles and other designs.
can anybody help
Thu, Dec 19, 2013 at 12:11:40 PM | Floor finish issues
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you talking for rendering purposes or just for a tile layout plan?
Fri, Dec 20, 2013 at 4:33:50 AM | Floor finish issues
zakazai
Dear teafoe5
Thank you very much for your kind response.
i have both needs, and more, pls note the following
1: i would like to give client a 2D plan with tile layout
2: i need to show the client rendered view according to the layout
3: if possible i need to get the schedule of the quantity of the tiles.
Kind regards
Abdul
Fri, Dec 20, 2013 at 6:47:20 AM | Floor finish issues
We usually do tile areas as thin floors which we layout in plan.  We sketch the shape of each different floor for each tile and apply the correct material that has a model pattern so that we can adjust it in plan.  The thin floor is placed just on top of the structural floor.
Fri, Dec 20, 2013 at 7:18:01 AM | Floor finish issues
zakazai
Thank you very much teafoe5
one last question
how do i get tile pattern on my rendered view, not in 2d plan.
and i just got info, i would like to share with u as well, pls click the link.
http://revitscratchpad.blogspot.ae/2011/06/modelling-floor-finishesthe-fast-way.html
Fri, Dec 20, 2013 at 7:20:30 AM | Floor finish issues
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to apply the material you want to see rendered to the floor.
Fri, Dec 20, 2013 at 7:41:00 AM | Floor finish issues
I think that bloggers method is just plain stupid.
Doing the thin floors is easy and easily scheduled in the correct category.
Sat, Dec 21, 2013 at 4:00:37 AM | Floor finish issues
zakazai
Thnks to all.
i am still stuck on making patterns on the material.
may be bcs i am new in revit.
i cannot see how to adjust tile lines.
Sat, Dec 21, 2013 at 4:09:36 AM | Floor finish issues
zakazai
ok , i got it
thank you revit helpers.
Finish Flooring as part of Structural Floor assembly
Fri, Dec 26, 2008 at 8:42:14 PM
Finish Floor
Tue, Jul 21, 2009 at 5:05:38 PM
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:05 PM
Subfloor Vs Finish Floor Elevation
Tue, Jul 15, 2014 at 7:58:04 AM
floor finish showing though
Thu, Oct 6, 2011 at 12:29:11 PM
Page generation time: 1.5807
