96 Users Online (95 Members):
Forums >> Revit Building >> Technical Support >> Setting Out Plans
Hi All
its my first post, pls bear with me for my noobness.
I've been using revit for over a year now, doing designs and also tender drawings. I'm now about to start up some construction drawings and immediately hit a wall with my Setting out plan. I've realized that there can only be 1 Project Base point and 1 Survey point.
Is there a way to create extra survey points that I can establish? these points shall serve as my setting out points on site with its proper coordinates. and if possible link them to site benchmarks with their proper bearings and distances.
Thanks in advance for any replies.
Under annotations, there is a spot coordinate tag. If you place a "pin" somewhere, you can use that spot coordinate tag to tag it. The pin might just be a crossed line on your site plan.
site plans and buildings plans |
Tue, Apr 17, 2012 at 8:40:07 AM
Using Area Plans as Main Floor and Unit Layout plans |
Mon, Mar 29, 2021 at 1:59:33 PM
How do I make framing plans? |
Tue, Jul 27, 2004 at 3:28:27 PM
Setting the View for Floor Plans |
Sun, May 20, 2007 at 8:26:43 PM
Help with my new website for hosting drafted plans |
Sun, Mar 22, 2015 at 10:14:01 AM
Members: | 2022253 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
