Forums >> Revit Building >> Technical Support >> Custom Ceiling Pattern - Armstrong Techzone
I am having a hard time figuring out a simple pattern to load into Revit as a .pat file created in note for a 48x48 ceiling tile that has a 6" x 48" segment every 96" -
Here is the .pat file that I typed up:
*48 x 48-6x48 Ceiling;%TYPE=MODEL0, 0,0, 0,4890, 0, 0, 0, 4890, 48, 48, 0, 4890, 54, 54, 0, 6
It creates the 48" spacing correctly in the 0 direction, in the 90 it only creates lines every 6" -
Try this:
; Written by HatchKit 2013 Hatch Pattern Editor
; HatchKit 2013 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2013
; www.hatchkit.com.au/
;%VERSION=3.0
;%UNITS=INCH
;%TYPE=MODEL
90,48,48,0,102
90,54,54,0,102 90,0,0,0,102
0,0,0,0,48
hth,
Hugh Adamson
www.hatchkit.com.au |
Woops, pasting ate a linefeed, this might be better:
;%VERSION=3.0
;%UNITS=INCH
;%TYPE=MODEL
90,48,48,0,102
90,54,54,0,102
90,0,0,0,102
0,0,0,0,48
Hugh Adamson
Thanks Hugh, that's exactly what I was looking for.
Armstrong Techzone has a lot of thes odd panel configurations already available pre-made. I didnt see the one i needed right away but after downloading the file there is a bunch of patters already created.
look under the "downloads" section: http://www.armstrong.com/commceilingsna/products/ceilings/techzone-optima-technical-panels/_/N-cZ1z141qu
Hugh,
Can you produce the same .pat pattern with a 24x72 tile w/ 6"x72" segment every 48"?
Integrated Ceiling Sytem, HOW? |
Sun, Mar 22, 2009 at 4:56:27 PM
Radial Ceiling |
Wed, Feb 23, 2011 at 3:35:07 PM
Specialty Ceilings from Armstrong not working |
Mon, Jun 4, 2012 at 3:20:49 PM
Custom Ceiling Grid |
Tue, Aug 7, 2007 at 2:41:37 PM
ceiling hatch pattern |
Thu, Apr 17, 2014 at 6:59:10 AM
Members: | 2116431 | Objects: | 23196 | Forum Posts: | 152302 | Job Listings: | 3 |
