104 Users Online (105 Members):
Forums >> Revit Structure >> Technical Support >> Opaque light fixture not emitting light
Is there a setting to make a light fixture component transparent to light? I have had this problem with even stock light fixtures: light does not emit from the fixture unless one makes the light source outside of the fixture.
yes. add a transparent material to your cylinder. i can see it is still default gray.
you might want to add a self-illumination parameter to the transparent material as well.
** dont be mad, i dont have much... i am homeless |
@ronmalit - Transparency tip, perfect. http://screencast.com/t/oMQVEucj Your disclaimer gave me a laugh, btw. I'll tread carefully.
for others (like me) that have never used a self-illumination parameter, here is where you find it: http://screencast.com/t/fRrA9dAu
even when I set self-illuminance to a 10,000 luminance, it doesn't appear to iluminate or glow. http://screencast.com/t/oVadd8WOU5 Should "self-illuminance" result in an illuminated appearance?
yes it will. and the effect is always nicer if you post process it in photoshop.
Light fixture doesn't produce light |
Sat, Jun 7, 2008 at 12:39:38 PM
trying to make custom light fixture w/ 2 light sources - need help |
Mon, Jun 22, 2009 at 6:23:45 AM
Lighting fixture not showing ANY light |
Fri, Apr 10, 2009 at 12:30:55 PM
Generic Model turned Light Fixture not rendering |
Thu, Aug 2, 2012 at 9:57:59 AM
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
Members: | 2022270 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
