Forums >> Revit Building >> Technical Support >> Unable to select grid lines after pinning them
I am using Revit 2014. I decided to pin my gridlines, because everytime I would pan on the page I was working on, I would accidently grab the grid line and move it. Unfortunately, once I pinned the grid, I can no longer select it! I am able to dimension to it, take a measurement from/to, etc. but I cannot select it to un-pin it and edit it, hide it, or adjust the tails, etc.. I also tried selecting the 'unpin' command first, but am still unable to select the grid. HELP!
I cannot think of a reason for this. Try dragging a selection box from right to left, over a portion of the grid line. This will select anything it touches.
Now, filter your selection to remove all items selected which are not grid lines. If you have a DWG or image underlay, sometimes it seems you cannot select anything because your selection box is outside of your field of view.
I just tried this. Now, I noticed that I am unable to select ANY pinned objects! I have some equipment linked from an AutoCAD file, that I had pinned and now I just noticed that I cannot select it either. I did a window from right to left and it wouldn't select any of the objects that I have pinned.
Found it!!! In the bottom right hand corner, I had somehow turned off the select pined objects button! Whew! Not sure how I did that, but glad I found it!
I feel old and out of practice--I've never seen that checkbox. Glad it wasn't something too puzzling.
Don't feel bad, that is a relatively new button. I answered a question wrong the other day about segmented grids because they snuck that feature in on me.
Can't select gridlines |
Fri, Oct 3, 2014 at 10:00:47 AM
Unable to Align |
Mon, Sep 8, 2008 at 12:27:44 PM
Grid Lines & editable dimensions |
Mon, Mar 30, 2009 at 6:11:39 PM
disappearing grid lines |
Wed, Apr 19, 2006 at 5:44:49 PM
Break Grid lines |
Sun, Jul 18, 2010 at 9:36:16 AM
Members: | 2101683 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
