147 Users Online (146 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Splitting the ground floor slab?
Thu, Dec 12, 2013 at 10:41:36 AM | Splitting the ground floor slab?
montri
Hi,
Can someone please tell me how I can split the ground floor slab into separate slabs where I can then go and edit the type of floor so that they have a different stratification?  Because I tried splitting it with the split tool when I edit boundary, but when I try to select one slab, it just selects the whole thing and I can't independently edit them.
Thank you!
Thu, Dec 12, 2013 at 10:44:54 AM | Splitting the ground floor slab?
Create two floors.
Copy the floor to clipboard then edit the floor removing half of it.  Now paste the copied floor back in (same place) and edit that floor removing the other half.
First floor slab or ground floor ceiling?
Fri, Aug 30, 2013 at 7:41:03 AM
Wall top vs. First floor slab
Thu, Jul 8, 2010 at 10:40:55 AM
Architectural columns from the level below are displayed on the slab
Tue, Apr 2, 2019 at 4:50:35 PM
Window from floor above showing on ground floor plan
Mon, Oct 10, 2016 at 7:13:10 AM
Color Scheme and Floor Heights
Thu, May 21, 2009 at 1:04:10 PM
Page generation time: 0.7512
