108 Users Online (106 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Multiple Wall Finishes.
Wed, Dec 11, 2013 at 10:00:29 AM | Multiple Wall Finishes.
scottwilson
To all out there....   how do we assign multiple finishes to a wall and tag each finish without making major
changes to the structure of the wall,  we have a room within a room basically which has the same structure with
various different types of finishes.
many thanks
CG
Wed, Dec 11, 2013 at 10:11:00 AM | Multiple Wall Finishes.
Are all of the finishes on the same base like paint is?  Simply split the surface in elevation and paint the color (finish).  Unless we need it for rendering or material takeoffs, we do this all as 2D only graphics.
NOTE:::: You can only tag these finishes in an elevation view.  In a plan or section view, only the cut material will tag.
Thu, Dec 12, 2013 at 10:57:04 AM | Multiple Wall Finishes.
scottwilson
cheers wwhub,
you mention 'only the cut material will tag.' what if i have a solid brick wall which will receive
two diffrent paint finishes on either side ??  plus what parameter must be incl to pick up these
two finishes..
regards
Thu, Dec 12, 2013 at 11:02:30 AM | Multiple Wall Finishes.
Look at what I said.   Only the material in plan or section that is exposed by the cut plane will tag.   In other words, the material has to be there at the view plane - not above or below it.  Obviously all materials on a wall face are taggable in an elevation view.  You can only tag what you can see!
Edited on: Thu, Dec 12, 2013 at 11:03:11 AM
Room tag - multiple finishes per room
Tue, Oct 14, 2008 at 2:21:50 AM
Internal Wall Finishes
Tue, Mar 25, 2014 at 4:18:19 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:33 PM
wall finishes by room
Tue, Apr 19, 2005 at 11:40:26 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:11 AM
Page generation time: 1.2343
