18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> New fill pattren
40 Posts No Rating |
How do you create a new fill pattern for a wall or roof, from scratch? If I create a new hatch in Autocad, Can i take it to revit?
Thanks.
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
you can create what ever pattern you want using a:
1. text file, if you know what you are doing, and save as .pat and import to revit
2. a third part program (can't remember the name) and import into revit
what "if you know what you are doing" means?
How do you create a pattern from a text file?.
Do I have to draw the pattern in the text file? That sounds a little crazy.
help...
![3 Stars: 1 Votes](/images/stars_3.gif) |
Someone suggested this software:
http://www.cadopolis.com/autocad_addons/GlobalCAD_Hatch-Manager.shtml
We use HatchKit:
http://cadro.com.au/hatchkit/index.html
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
help...
if you open a pat file in notepad for example, you'll see that its all stored as co-ordinate data. That's why eldad say "if you know what your doing" as its a little tricky...
Post edited on 2006-02-21 17:16:37
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:36 AM
Fill Region Not Showing |
Wed, Aug 22, 2018 at 5:28:47 PM
Revit 2009 - Fill Patterns |
Sun, Nov 21, 2010 at 9:17:43 AM
fill pattern and line style |
Thu, May 5, 2005 at 6:25:07 PM
Solid Fill Hatch |
Sun, Apr 1, 2007 at 8:56:31 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
