66 Users Online (65 Members):
Forums >> Community >> Newbies >> Section Markers and Issues
Im not new to Revit but Im new to the forum here and wanted to ask some questions.
I am working with an existing template and using the section marker. When I import it vertically, it is fine (the lines and text is fine). When I rotate it or import it horizontally, the line inside the bubble rotates as well (but the text doesn't). This causes the line inside to be right through the text Any one know how I can edit those properties so the line inside the section bubble doesn't rotate?
Also, I want the inside of the bubble to be opaque so when placed within a ceiling plan, it shows over the ceiling hatch.
I appreciate any help you all can offer!
Thanks
The standard section markers should look like the attached. If they don't then you are using a custom marker that may not be bult correctly.
Scaling section and elevation markers |
Thu, Jul 26, 2012 at 7:13:35 AM
Elevation Markers, Level Heads, Section Markers, all at Varing Scales |
Mon, Feb 20, 2012 at 11:33:58 AM
Red Section Markers |
Thu, Feb 28, 2013 at 8:13:10 AM
Rev 2009 Section Markers |
Wed, Aug 17, 2011 at 8:25:09 AM
Printing Issues |
Fri, Jul 27, 2007 at 10:03:44 AM
Members: | 2030542 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
