80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> Trouble with Roof
0 Posts No Rating |
I'm really struggling with this roof on this model. I've attached the file if someone could take a a look and help.
I've got this set up as a bunch of individiual roofs but i think it can be done with almost all one roof. I really struggle with the roofs in revit.
Can anyone give me a hand and show me the best way to make this work?
0 Posts No Rating |
Hi Arkman
It models up fairly simply if you exclude the bay window roofs (though I'm not sure how you intend it to look at the back of the garage?).
I just picked all the external walls with the same overhang, break the lines at the two bays and draw new lines at 45° inwards from the junction with the bay roofs. At the opposite end to the garage, split the outer line (running N/S) at points that align with the perpendicular lines before picking the two outer segments as defining the slope. Align the eaves (adjust height not overhang).
With the bay roofs its just a case of adjusting the pitch of the splayed facet to get them to meet at the right point (I got as near as curse it by making that 5 5/16"in12")
Cheers,
Cadence
0 Posts No Rating |
Thanks for the help! Sorry for the delay, I had to step away from this for a while.
I am going to inspect it to try and learn how it works. I always struggle with roofs in revit and to see how someone else does it will be super helpful!
Thanks!
Roof Join / Entension Trouble |
Thu, Feb 11, 2016 at 9:52:09 AM
Trouble with Roof |
Tue, Jun 10, 2008 at 8:33:43 AM
Roof Extrusion Trouble |
Tue, Mar 5, 2013 at 12:43:01 PM
Dome roof |
Mon, Jan 17, 2011 at 7:52:22 AM
13
Wall, window, and roof. Trouble getting the window to not go through roof |
Tue, Mar 15, 2011 at 1:40:00 PM
Members: | 2056491 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
