61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> always prints 2 copies of some sheets?
57 Posts No Rating |
When printing from a particular drawing file, there are two sheets, (out of 28 ), that always print two copies -regardless of which printer is used. One of the printers is a PDF generator, so it tries to print two files of the same name...
Any suggestions?
Edited on: Fri, Dec 6, 2013 at 11:26:19 PM
I think I have seen this before but I don't know how it was corrected. You don't say what Revit and what updates. You should always include that in your posts. This might be solved with an update or it may be a corrupted file.
25 Posts No Rating |
I had this issue with revit 2013 (or was is 2012?). Haven't run into it with 2014.
Palm Springs Architect using Revit LT! |
Scaling Hard Copies |
Mon, Nov 1, 2010 at 7:07:45 PM
double prints |
Tue, May 27, 2014 at 9:25:48 AM
missing walls, fixtures in pdf prints |
Mon, Jul 3, 2006 at 3:41:57 PM
Room Tag Missing in Copies & Callouts of Floor Plans |
Mon, Dec 10, 2007 at 11:55:32 AM
Strange printing problem |
Tue, Aug 11, 2009 at 10:41:44 AM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
