74 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Surface pattern problems
30 Posts No Rating |
I am using a tile surface pattern on a bathroom floor and the problem is that is show through everything- the fixtures, the doors, cabinets, etc. Is there any way to make it so that the pattern will only show through in space and through solid objects?
See attached image
one quick way would be to not use the tile pattern in plan, and use a filled region in the area you want to have hatched. it isnt the most desireable solutions, but if you are in a bind that will work. i had to use that as a temporary solution a couple of times.
Thanks for the idea but I am looking for a solution that will work more permenant solution.
![3 Stars: 1 Votes](/images/stars_3.gif) |
You can try this:
1. Create a Detail Component with a solid Filled Region in the shape of your fixture
2. Import that Detail Component into your Plumbing Fixture or Furniture Family
3. Draw an vertical invisible model line
4. Insert the new family into your project
That's for 2D Furniture and Fixtures.
For 3D Furniture and Fixtures just make the components VISIBLE in Plan View
Post edited on 2006-02-17 22:52:10
![danpecor Avatar](user_avatar/28244.jpg)
If you have Revit 2008, you can add a masked region to the plan view of your fixture families. This will cover anything beneath it, including surface patterns.
1 Posts No Rating |
Danpecor mate, thanks for the tip! was getting quite stressed about it... it works fine and it was easier to do than i thought it would be....
p.s. funny! a few years later!
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
surface pattern visibility issues |
Thu, Jan 5, 2006 at 3:13:47 PM
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
voronoi surface pattern |
Fri, Jun 24, 2011 at 2:14:03 PM
Members: | 2022314 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
