69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Turning certain curtain panels into spandrel panels
Tue, Dec 3, 2013 at 1:19:26 PM | Turning certain curtain panels into spandrel panels
Sycamore1
I have a store front curtain wall and individual panels separated by mullions. What I need to do is turn some of those panels into spandrel panels but when I even try to just change one they all change. What am I doing wrong? Thanks.
Tue, Dec 3, 2013 at 1:30:17 PM | Turning certain curtain panels into spandrel panels
You are modifying the single type panel you now have.  You need to duplicate type and create a new one with the thickness and material you need for your spandrels.
Tue, Dec 3, 2013 at 1:40:14 PM | Turning certain curtain panels into spandrel panels
Sycamore1
Ok, I selected one of the panels, duplicated type and named it Spandrel Panel, and changed it to the material I would like with tint and color and they are all still changing. I'm not sure what I am doing wrong still.
Tue, Dec 3, 2013 at 1:48:11 PM | Turning certain curtain panels into spandrel panels
You are changing the material now that is used on both panels.  You can't do that either.  You need a new material and if this is 2013 or 14 then you have to pay attention to the asset.  Spend some time in your help - materials and how to create them.
Tue, Dec 3, 2013 at 1:51:23 PM | Turning certain curtain panels into spandrel panels
Also - is your curtain wall fully defined?  In other words, are the spacings, mullions and panels pre-defined?  If so then you need to unlock those or better yet, change the curtain wall to one that has no pre-set elements.  Then change the appropriate panels to spandrel/
Again, watch some videos on curtainwalls and read your Help.
Tue, Dec 3, 2013 at 1:52:07 PM | Turning certain curtain panels into spandrel panels
Sycamore1
Yeah it's Revit 14. But I will do that, thank you!
Tue, Dec 3, 2013 at 1:59:47 PM | Turning certain curtain panels into spandrel panels
Sycamore1
It's working now! Thank you!
Nested Spandrel in Curtain Panel
Thu, Aug 9, 2007 at 7:01:51 PM
Windows with spandrel panels
Fri, Jul 21, 2006 at 2:57:56 AM
Windows with infill spandrel/panels
Fri, Jun 15, 2012 at 9:38:54 AM
Spandrel Panels At the Ends of Wall
Mon, May 15, 2006 at 8:06:07 AM
Revit - Curtain Panels Mitre Joint Issue! Please Help!
Tue, May 28, 2013 at 8:58:14 PM
Page generation time: 0.5876
