62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Vertical Fascia on Roof by Extrusion - Is it possible?
Tue, Dec 3, 2013 at 11:16:07 AM | Vertical Fascia on Roof by Extrusion - Is it possible?
PBWC
Hi all
Have created a vertical element of roofing which curves down over an external wall. I want to create a continuous element of fascia, however, fascia can only be applied to the piece of roof created using 'Roof by Footprint' and will not automatically snap to the vertical element of roof.
Any ideas?
Using Autodesk Revit 2014
Thanks
Lee
Tue, Dec 3, 2013 at 11:21:34 AM | Vertical Fascia on Roof by Extrusion - Is it possible?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
A roof cannot be totally vertical.  Can you attach an image of what you are trying to do?
Wed, Dec 4, 2013 at 7:03:15 AM | Vertical Fascia on Roof by Extrusion - Is it possible?
PBWC
Thanks for the reply.
My roof is totally vertical created by using Roof by Extrusion tool..
I have overcome this I think by using an in-place family and a sweep to create my profile for the length of the vertical section.
I'll post up a image later.
Thanks
Lee
Wed, Dec 4, 2013 at 9:44:50 AM | Vertical Fascia on Roof by Extrusion - Is it possible?
PBWC
See image attached.
Thanks
Lee
ARCHED ROOF FASCIA
Fri, Apr 21, 2006 at 3:33:18 PM
arched roof edge
Fri, Apr 21, 2006 at 4:30:22 PM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:24 AM
Roof fascia curves in plan and elevation
Sun, Dec 13, 2009 at 1:40:45 PM
Roof Fascia On Negative Sloped Roof
Wed, May 15, 2013 at 9:47:36 AM
Page generation time: 1.8476
